Hello,
I am new to the form and have some general questions about the 1953 ford golden jublee Naa 1 tractor I picked up for a new project.
1. the trator is wired positve from battery to the starter seliniod and ground from the battery to ground. It is the 6 volt w 3 lead generator but no votage regulator? It looked like the origanal wire harness that I removed. All of the info i found on the tractor says that it is positive ground and to a voltage regulaor.
I have seval wire diagrams on it from differant sources.
Need some help on this first stumper.
Is there supose to be the voltage reulator or is it in the generator?
Are the wires from the battery correct to the pricable of the positive ground system? I am not believing so.
Thank you for you help
