Hi guys I need some more help. I got a ford 3000 tractor that I baught about 2 hours away from my house and it ran perfectly fine. After transporting the tractor it would only run with the choke out. Replaced the tank (the shutoff valve for the tank with screen) Cleaned the fuel pump out, blew out all of the lines and cleaned and rebuilt the carb. It still is having the same issue however after adjusting the carb a little bit i can get it to run with the choke in however with 5% throttle applied. If I try to turn up the throttle it runs for a few seconds then will die unless I pull out the choke. Any thoughts on what else it might be? Please don't tell me to replace the carb with another one I have seen this tractor work flawlessly and I think the car ride home shook something loose.
Thanks in advance.
Thanks in advance.
