TractorLinks.com
Show Parts for Model:
Re: SOS Band adjustment warning
jeff pk
04-18-2013 13:22:37
So, if it's acting like the sequencing valve is broken, but it's not, what else could be causing that action?
Larry NCKS
04-18-2013 14:29:04
 Re: SOS Band adjustment warning in reply to jeff pk, 04-18-2013 13:22:37
I already answered that question once.
"Re: Technically challenged SOS repair in reply to jeff pk, 04-16-2013 16:03:36
I've forgotten - why did we suggest this pin to begin with? Are you missing 5,6,7 & 8? If so remind us which tractor you have again. If this is the scenario, B2 is failing to apply for some reason. The little pin is the most common culprit. Since this is a spring applied band, one would guess a sticking B2 valve keeping hydraulic pressure applied as the next most likely cause. Either that or the band is shot, broken or not adjusted properly.
Since you believe you've dropped a strut anyway, you'll likely get the chance to look the innards over well. Check it all out. Let us know what you find."
This post was edited by Larry NCKS at 14:30:38 04/18/13.
jeff pk
04-18-2013 16:33:03
 Re: SOS Band adjustment warning in reply to Larry NCKS, 04-18-2013 14:29:04
Thanks for the re-reply Larry.
