TractorLinks.com
Order Ford 3000 Parts Online
Re: Ford 3000 only runs with choke out.
reb-in-pa
04-18-2013 04:10:29
Stevo --
Check the fuel flow by removing the big screw on the bottom of the carb. Have a pan ready and open the shut off. You should get a thick, steady stream. If not, you have a blockage somewhere upstream of the carb.
As for the wire check: checking the sparkplug wires is always a good thing, but that's not what could be your problem here. I was referring to those skinny little wires that go onto the two nutted connections of your coil. Sometimes you can make a broken or frayed woven wire fail on demand by wiggling them around. The last time I had this happen, the last strand of wire failed when I wiggled, and the wire broke completely off. One of the best ways to test would be to put on temporary jumper wires and try it.
Good luck.
Ray
3000OH
04-18-2013 17:37:08
 Re: Ford 3000 only runs with choke out. in reply to reb-in-pa, 04-18-2013 04:10:29
Also be sure to check the battery cables, all the way down to the starter. A known place where these crack, esp. at the battery tray & below, then arc over to metal & start fires. Bought some parts off a 3000 diesel that had that happen - torched itself in a barn while just sitting there with engine off.
