Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Order Ford 3000 Parts Online
Re: Ford 3000 only runs with choke out.
Hobo,NC
04-17-2013 19:01:44
pump should move EZ enuff it would fall out on its own... A wire plumbers brush will clean up the bores...
Make sure all the passages are clean run a wire thru'em if need B
Make sure the accelerator check valve checks one way...
The metering body to carb body gasket needs to fit dead nutz perfect you may have to trim it were it butts again the carb body and make sure it stays aligned while nailing the metering body down...
I have repaired 8 are 10 of'em and all have performed great... Its as simple a carb as it gets but unlike most tractor carbs its more like a automotive carb... They can not be beat when they are right...
I have done over a 1000 and maybe 2000 automotive carbs I felt right at home with them... It would not make me mad if I never see another carb again I like EFI... BTW I use TISCO kits and have had good luck with them other than having to trim the metering body gasket to fit a tad...
