Ford 850 Drawbar
I have a Ford 850 tractor that needs a drawbar. I have the piece fits between the 3 pt hitch arms. What drawbar do I need? How long, etc?
Jeff
there's been som custom work done on that under diffy bracket you may have to undo before getting the swinging drawbar with roller and pin
(quoted from post at 18:22:21 04/17/13) there's been som custom work done on that under diffy bracket you may have to undo before getting the swinging drawbar with roller and pin
The bracket is bent. Where can I get the drawbar, roller, etc?
The damaged, incomplete bracket pictured appears to be the under differential drawbar bracket for an 8N. It is not OEM for an 8** tractor.
Complete aftermarket drawbar assemblies for 8** tractors are still available.
Dean
In the manual I have it shows an accessory drawbar in the picture below. Are those still available? The only ones I've found so far are like what is on the 8N I have. Could the bracket on the tractor be for the type of drawbar in the picture below?
Jeff
(quoted from post at 04:19:31 04/18/13) In the manual I have it shows an accessory drawbar in the picture below. Are those still available? The only ones I've found so far are like what is on the 8N I have. Could the bracket on the tractor be for the type of drawbar in the picture below?
Jeff
J. you aroused my curiosity so I looked it up. What you have is called a "Clevis hitch" with a plate added to the rear. It is to accommodate the swinging roller draw bar that you have pictured. I have never seen one before. They must be rare, and of course no longer available. If I were you I would get an aftermarket draw bar and have the roller fabbed up, and bolt it on per your picture.
(quoted from post at 16:43:28 04/26/13)
(quoted from post at 14:01:27 04/18/13) Here's the drawbar.
Drawbar
I got the drawbaron ebay. It would have been much better if the piece of metal wasn't on top of the clevis hitch but it works.
Jeff
Congratulations! It is always nice to have something unusual. I would just cut that added piece off.
(quoted from post at 19:43:28 04/26/13)
Drawbar
Jeff
Maybe there to protect your PTO shaft? Just a WAG.
