TractorLinks.com
Show Parts for Model:
Re: 4 speed power reversing trans no foward or reverse
Shaun Wallace
04-17-2013 04:48:40
As JF posted no pump pressure Id suspect broke flex plate. witch is a fair sized job.
rogerm
04-17-2013 12:53:40
 Re: 4 speed power reversing trans no foward or reverse in reply to Shaun Wallace, 04-17-2013 04:48:40
Its not making any noise at all so I am sure the drive plate is fine. Had this apart about four years ago and bought an overhaul kit and a new converter, pump Probably only have maybe a hundred hours at the most on it. Once the blocker valve stuck on me but if i remember right it had me stuck in forward could not select reverse.
But so I checked the fluid the day this all happened it was low so i took it up to the level. Just noticed today I used the hyd.oil for my 12000lb car lift its
ISA 46 fluid Not my trans hydro oil It has been ran with this oil in it so it is all through the system. what is the proper steps in flushing this all out.
once again thanks for any input
