TractorLinks.com
Order Ford 640 Parts Online
Re: 640 no hydraulics
dmiller
04-16-2013 19:28:01
I'll have to crack the bolts at the bottom of the hyd. manifold to see if there is flow from the reservoir there.
It's a vane pump (square, no plug that I can find). Not sure how to bleed out the air??
Can I fill the plug at the top of the hyd. cover (one on the right in front of/under the seat). If that connects to the pressure line would you be able to fill the pump from it??
Also while I'm at it is this plug where you would plumb in a valve for a hyd. remote??
JMOR
04-16-2013 20:01:57
 Re: 640 no hydraulics in reply to dmiller, 04-16-2013 19:28:01
Quoting Removed, click Modern View to seeThere is a plug way down low near front of right running board. Remove it & see if pump will flow there. If nothing there the pump isn't pumping as there is nothing but your sleeved tube between that & pump outlet. The plug in assessory cover is well beyond control valving & therefore not exactly meaningful, as if flow there during lift command, you would have lift.
