Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: Technically challenged SOS repair
jeff pk
04-16-2013 18:31:05
Okay I'll try that. Do I need to put the interlock cover back on or can I do it removed with the adjusting screw just turned in?
Leave it in Park?
Thanks
Larry NCKS
04-16-2013 18:35:46
 Re: Technically challenged SOS repair in reply to jeff pk, 04-16-2013 18:31:05
interlock cover does not matter for this test.
transmission is always in Park when the engine is not running, no matter what position the shifter is in.
jeff pk
04-16-2013 19:09:41
 Re: Technically challenged SOS repair in reply to Larry NCKS, 04-16-2013 18:35:46
Wheel turns, with some heavy resistance that's not there when the lever is disengaged.
Larry NCKS
04-16-2013 19:51:03
 Re: Technically challenged SOS repair in reply to jeff pk, 04-16-2013 19:09:41
if you're sure both bands are tight, you shouldn't be able to turn that wheel.
I'm gonna guess you dropped the strut as you suspected.
Wanta haul it to Kansas??? :lol:
jeff pk
04-17-2013 10:41:23
 Re: Technically challenged SOS repair in reply to Larry NCKS, 04-16-2013 19:51:03
Can you tell me what is involved with the retrieval and replacement of the strut I dropped?
Larry NCKS
04-17-2013 10:49:59
 Re: Technically challenged SOS repair in reply to jeff pk, 04-17-2013 10:41:23
Transmission split from center housing at rear. Rear gut until you get in far enough to fix your problem.
You'll need a rear transmission housing gasket, a transmission to center housing gasket and oil for the hydraulic section as a bare minimum.
