Since re-sleeving the pressure line I still have no 3pt. I tried to pump air in the dip stick hole to prime the pump (did this for about 2 minutes, twice) no 3pt still. I tried backing up on a hill so the reservoir was higher than the pump, sat there at half throttle for about 2 minutes.
Checked the plug on the top right (beneath /in front of the seat) of the reservoir cover. While tractor off there was a bit of fluid there (appeared milky, like the old fluid before I re-sleeved, bubbly as well), no change or pressure while tractor running.
Drove around for about 4 minutes to double check the hyd and tranny fluid weren’t mixing. No change to hyd. Fluid level.
Not sure what to try next, really need the tractor this weekend if possible.
Ideas or suggestions??
