TractorLinks.com
Order Ford 3000 Parts Online
Re: Ford 3000 glow plug
Sean in PA
04-16-2013 06:28:11
Actually, the term solenoid comes from the science of physics and refers to a coil of wire that can produce a magnetic field. In engineering it generally refers to a coil of wire used as an electromagnet to control the linear movement of something. A relay is a specific kind of solenoid that uses a small electric current in the electromagnet coil to move the contacts for a switch that can then control a much larger amount of current. The term solenoid is also used in hydraulics and pneumatics to refer to electromagnetically controlled hydraulic and pneumatic control valves.
See: http://en.wikipedia.org/wiki/Solenoid
