TractorLinks.com
Order Ford 3000 Parts Online
Re: Ford 3000 glow plug
Texasmark1
04-16-2013 05:23:54
10 ga speaks of 30 amps. That heater gets red in just a few seconds. Even at 10 amps x 12v, that's only 120 watts. Think about the typical electric soldering gun that it rated at 100w. You push the button and it takes awhile for it to start smoking, much less do any glowing.
I like the solenoid idea as the energizing current can be handled easily with most any spst momentary on, aka push button switch and 14 or 16 ga wire.
The solenoid could be placed at a convenient place and the large wire run would be shorter which is better.
I've had numerous so I get confused. I think my 2000D 4 cyl has a push button and you can hear the solenoid close but it uses a couple of glow plugs in the intake manifold....can see them from the side of the tractor below the hood.
I think my '65 3000 has a button also. Although my TS works, I don't recall tracing out the electrical ckt.
I think I had a 4100D 3 cyl once, and a '66 3 cyl D that had it in the key switch. You would turn the key to on and both warning lights would come on, turn it a tad more and they would go out.....when they went out the TS was being powered. Hold it there for about 30 seconds and roll the switch on over to start whereupon the power is still going to the TS but also to the starter. I would imagine that they have a solenoid/relay (same thing, just the term solenoid usually refers to a high current relay) too as you really don't want any high current going through the contacts of the switch......it wouldn't last any time at all.
Mark
Ultradog MN
04-16-2013 16:23:45
 Re: Ford 3000 glow plug in reply to Texasmark1, 04-16-2013 05:23:54
Part of the reason I was going to use a push button (or solenoid) is because I have two brand new ignition switches here - with thermostart -that I bought on Ebay a couple of years ago.
But the bloody things are not right. The neck that goes through the cowel is too small of a diameter so the whole darned switch turns when you turn the key. Grrr
sotxbill
04-17-2013 10:34:31
 Re: Ford 3000 glow plug in reply to Ultradog MN, 04-16-2013 16:23:45
Actually the switch size is correct and you have a tractor with an enlarged hole in the sheet metal. This is a real pain. You can washer it back and tighten the crapola out of it to keep it from turning on you. Even better is to tack the washers in place with a wire welder. The aftermarket switches are cheap but usually do okay for 5 or 10 years. Not the same quality as oem, but for 15 bucks, what do you expect. These aftermarket switches usually have the glow plug activated on a right turn and past "on", but just before "crank".
What's even more interesting is on the gas models, they do not support "ignition" during "crank", so you must have a correctly wired bypass jumper from the selenoid to the coil or it will not fire during a crank cycle, but then fire only when you release the switch back to "run".
