TractorLinks.com
Order Ford 2000 Parts Online
Re: ford 2000 axle seals 3 cylinder diesel
Sean in PA
04-15-2013 17:54:06
My I&T manual agrees with what Ultradog is saying. You've got to drill the bearing collar and split it with a chisel to get to the seal to replace it. Then you've got to heat the new collar to 800 degrees to get it swelled up big enough to be able to press it on, and then when it cools it shrinks to fit. That's why you have to destroy the old one to get it off. It is only the bearing collar, which is one piece, not "all that stuff".
If you don't have a manual you should get one. The I&T FO-31 manual is only about $30.00 and then you won't have to believe folks like us.
