TractorLinks.com
Order Ford NAA Parts Online
Re: naa 3 point dont work
JMOR
04-15-2013 14:11:05
Quoting Removed, click Modern View to seeYes, insert gauge in place of plug in top front of pump. Be prepared to see only about 40psi, as that is pressure during bypass, as set by backpressure valve. You can only see 2000psi when lift is commanded & lift arms are tied down such that they cannot rise (obviously not going to work, since lift doesn't try to lift), OR you can blockoff the feed into the top cover and measure. Pump ought to dump ~3gpm out that "gauge" port at virtually no pressure.
mike in mo
04-15-2013 15:48:03
 Re: naa 3 point dont work in reply to JMOR, 04-15-2013 14:11:05
not seeing 40 running wide open it has about 5psi
