TractorLinks.com
Order Ford NAA Parts Online
Re: naa 3 point dont work
Royse
04-14-2013 10:36:47
Which pump do you have, the square can vane pump or the newer round
can piston pump?
If you have the newer one there is a plug on the front of it that you can pull,
tractor off, put some oil in it to prime the pump and see if that helps.
You can also put a hose barb in that plug hole, run a hose back to the filler
on the hydraulic sump and see if it pumps oil through when you start it.
If you have the vane pump, priming it is done by using low pressure air
through the dipstick tube. There is another post on this just a little ways back.
Parts for the vane pump are very hard to find, or so I've read.
Let us know what you find, there are some really good hydraulic guys here.
JMOR
04-14-2013 11:09:36
 Re: naa 3 point dont work in reply to Royse, 04-14-2013 10:36:47
What does your pump look like?
[URL=http://s192.photobucket.com/user/JMOR_photo/media/Hydraulics_PTO/hundred_series_hyd/hyd_NAA_piston_vane.jpg.html][/URL]
