TractorLinks.com
Show Parts for Model:
Re: Select-O-Speed (SOS) Quick ID, ORC vs DDC
TONY JACOBS
04-13-2013 07:45:46
Hello Sean , Thank You , but the casting number and part number info is correct . The C0NN code was used because there was no update or revision until after 1962 . There could be some C2NN codes on other parts less visible then the common blocks , trans. , rear axles we speak of most often but every piece has a casting number(there is C0NN, C3NN, &C5NN casting on Sherman parts)Yes C0NN codes are on the 1962 Blue and Gray tractors but not the Red and Gray ones . If you look at the 310835 and 310837 4 speed and 5 speed trans. cases for the 01 series tractors there is no change from 1958 - 1965 , yet 801 rear axle center housings go from 310363 to 312480 to C0NN4024F , and I know the 310 to 312 was a Metal change from Pearlitic to a Malleable Steel as were 24" wheel centers going from 311701 to a B9NN1036A casting number were steel related because of cracking problems as were the rear axle housings . Casting numbers changed when a casting was revised or updated for some reason . Sometimes the revision was the same year as the original casting or not until two or three years later , so sometimes the prefix changes and sometimes only the suffix changes . Example the C0NN7006B DDC Trans. case has no drain underneath the case but C3NN7006B does have a drain plug under the case , without having all of the original Ford Blueprints I don't know of any other differences but there may be . Example B9NN6015B Block gas or diesel 1959 tractor factory installed spin oil filter adapter , C0NN6015C block gas or diesel 1960 tractor factory installed spin on oil filter adapter , C0NN6015J Block gas or diesel block is now cast for spin on oil filter and used past the end of tractor production in Dec. 1965 . Finally the rest of what you said is also correct which is just what I trying to explain . Thanks Tony
