TractorLinks.com
Order Ford 860 Parts Online
Re: Ford 860 is eating points.
Greg1959
04-12-2013 18:03:31
Soundguy- It is the IC14SB coil from NAPA that you recommended and the resistor from Radio Shack that OLD recommended (I don't remember the part #).
It must be the cheap points from Tractor Supply, because the contacts were sticking together but the armature was pulled away.
Thanks
soundguy
04-12-2013 18:40:39
 Re: Ford 860 is eating points. in reply to Greg1959, 04-12-2013 18:03:31
well.. this ain't a diner.
you can't mix n match advice.
if you are running a napa ic14sb coil on 12v.. you don't need a resistor.
if you are running a resistor and that coil.. you are asking for problems.
if you are running tisco points.. you must liket to gamble. probably safer to run around with scissors than use tisco points...
