TractorLinks.com
Order Ford 600 Parts Online
Re: Ford 600
JD50A
04-12-2013 16:46:01
Help--Just talked to the owner about visiting tomorrow. he said the clutch is stuck! But, he would FREE IT UP. If it is stuck how can it be freed up without splitting the Tractor to get to the clutch? Said it runs good and he has been driving it around. How can you drive it with the clutch stuck, Start and stop in gear! Starting to sound like I should pass on this one?? Any help appreciated. Thanks
old
04-12-2013 16:59:10
 Re: Ford 600 in reply to JD50A, 04-12-2013 16:46:01
Very common problem on most any tractor. To free it up the guy will m9ost likely drive it around in a high gear holding the clutch pedal down and hit the brakes off and on. As for how he does it yep he starts it in gear which again is not all that hard to do. One common thing to help keep a clutch from sticking like that is to block the pedal down when not being used. I have an 8N that has a cement block on the pedal right now because of that problem
