TractorLinks.com
Order Ford NAA Parts Online
Re: NAA lift suddenly stopped
JMOR
04-12-2013 14:10:17
Unlike the piston pump, there appears to be no inlet & outlet plugs on the pump itself to permit the release of air (outlet) nor on the inlet/suction to allow the introduction of hydraulic oil. This leaves the outlet release point as the test port plug on the lower right side of center casting, near foot board/right brake. You can remove that and start to see if air on outlet is keeping it from pumping. I think this is not a high likelihood. Introduction of oil into the inlet is probably a better shot at success. This is done by applying compressed air to the dipstick hole with an air compressor blow-gun to help force oil up into the pump inlet. Other option is less desirable. Remove the pump, turn it upside down and fill it with oil, work pump to thoroughly coat insides with oil, being sure it actually pulls in oil at intake & forces it out the outlet when rotated. Pour oil into the suction line...gravity will never let you fill the line, but at least some oil will now be known to be in the line. If you need pictures of the test port location, view picture.
B Seifert
04-23-2013 15:42:44
 Re: NAA lift suddenly stopped in reply to JMOR, 04-12-2013 14:10:17
OK guys I had it working, but it loses prime if it sits more than a day or so.
I took the pump apart and found that the main seal on the shaft is hard. I believe it is sucking air and losing prime.
I think with a speedy sleeve on the shaft and a new seal it will work again. Problem is : Where do I get a seal for this vane pump. The avenues I have persued have so far come up empty. Any help would be appreciated. Bill
