Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: 3pt power lift problem
old
04-12-2013 08:12:54
3 point hyd lift is power up gravity down so yep you have to have weight on it to make it go down. Think of it this way if you get a milk shake and suck some into a soda straw and then pull it out the straw stays full till the shake either melts or you blow or suck it out. Same thing applies to the 3 point and the cylinder is full of oil so the weight of the arms are not enough to push that oil out unless it is real warm or you push it out
HMA
04-12-2013 08:29:44
 Re: 3pt power lift problem in reply to old, 04-12-2013 08:12:54
Old,
Isít normal to raise and lower the arms by my hands when the hydraulic lever is in the down position.
old
04-12-2013 08:55:03
 Re: 3pt power lift problem in reply to HMA, 04-12-2013 08:29:44
Yep you can raise or lower the 3 point arms by hand. The way things are made the arms are pushed up by a part that just sits on another part so yep you can lift the arms up by hand
HMA
04-12-2013 09:07:13
 Re: 3pt power lift problem in reply to old, 04-12-2013 08:55:03
Thank you, Old. Now I know how 3pt power lift works
old
04-12-2013 09:13:33
 Re: 3pt power lift problem in reply to HMA, 04-12-2013 09:07:13
It is done that way so things like a back blade can sort of float instead of holding down so if it hits a high spot you would have the rear tires loose traction and stop you
HMA524
06-24-2013 08:40:00
 Re: 3pt power lift problem in reply to old, 04-12-2013 09:13:33
Hello old, I did not start my tractor for about one month. This weekend I tried to start it but did not start. It looks like too much gas in it. Any ideas on how to get it started
Thank you
