Yesterday's Tractor Co.
Shop Now View Cart
Show Parts for Model:
Re: Select-O-Speed (SOS) Quick ID, ORC vs DDC
04-12-2013 06:25:28
KCM , 312259 Transmissions are OVER RUNNING CLUTCH in the 1959-1962 Red and Gray Ag tractors and Red and Buff Industrial tractors unless as Larry has said it was a Dealer Warranty Modification to a DIRECT DRIVE CLUTCH which there was a few done that way . C0NN7006B Transmissions are DIRECT DRIVE CLUTCH which Ford started installing in the NEW 1962 FORD BLUE and GRAY tractors in AUGUST of 1962 , which again there is not a lot of them more common is the LATER REVISION C3NN7006B DIRECT DRIVE CLUTCH Transmission which was installed in the 1963-1965 tractors . I have been working on S-O-S 'S for over 30 years and own all casting number trans. in the original tractors that they were installed in from the factory and speak regularly with the Ford tractor engineers that were there when they were new and are still around today . Thanks Tony
05-17-2013 11:26:49
 Re: Select-O-Speed (SOS) Quick ID, ORC vs DDC in reply to TONY JACOBS, 04-12-2013 06:25:28
i just got a select o speed and was brush cutting, it stop moving forward. could you please tell me what might be the problem with it. i also have tried to locate the seriral number and have not found it. i did find a number off the transmission case 312259 thanks for any information.
04-12-2013 14:44:54
Thanks Tony. Great info to know.
