62 4cylinder 2000 sos gas
Anonymous-0
wire coming out of top of trans sos need to know where to hook up. will start in any gear want it too start in park and neutral it has two wire switch and push button start gene
The wire connects to the Park start switch. It is the return path to ground for the solenoid primary circuit.
If the tractor starts in any gear, someone has defeated the Park start circuit, probably by grounding one side of the start switch.
Dean
