Rebuilt 172 ci motor. 174 hours on motor. Third set of points just burnt up. 12 volt negative ground. DELCO 10SI alternator w/ NAPA coil. Inline RadioShak resistor. Points gapped at 0.025. Autolite 437 plugs.Ignition switch good.
She starts on the touch of the starter button and runs great. Does anyone know why I'm eating points up?
P.S.- I'm always sure to cut off fuel and turn off the ignition switch. Also, I have checked the voltage going to the points with the ignition in the off position and meter reads zero voltage.
