TractorLinks.com
Order Ford 860 Parts Online
Re: Ford 860 is eating points.
Greg1959
04-11-2013 17:35:24
Royse- Thanks for your reply. I think it might be the "China" made points I bought at TSC. Believe I might try the HEI system by Petronix offered here. What is your opinion?
old
04-11-2013 19:05:34
 Re: Ford 860 is eating points. in reply to Greg1959, 04-11-2013 17:35:24
Cheap point is the problem. Go to NAPA or O'Reilly's and buy a good set of points and be dome with it. My 841 has had the same set of points in it for at least 10 years now and it starts up just fine knock on wood.
juniur
04-12-2013 04:55:37
 Re: Ford 860 is eating points. in reply to old, 04-11-2013 19:05:34
if the polarity on the coil is reversed it will burn the points
old
04-12-2013 07:48:45
 Re: Ford 860 is eating points. in reply to juniur, 04-12-2013 04:55:37
That is a myth. Voltage does not care if it flows forwards or back wards and the point see the same actions no matter which way the coil is hooked up just the spark jumps back wards or in other words if when hooked up + side to the ignition and the spark jumps from left to right if hooked up - to ignition the spark would jump right to left but either way the points see the same voltage so they wear the same either way
36 coupe
04-12-2013 06:35:59
Not so.Bum info.
