TractorLinks.com
Order Ford 800 Parts Online
Re: Ford 800, PTO engaging problem
old
04-02-2013 08:26:56
800 as in what model?? May help us help you. I would start by pulling the inspection plate off that has the PTO shifter and have a look so to make sure that the lever is moving as it should and also to see if you can engage the PTO by hand with the engine NOT running for safety's sake
soundguy
04-02-2013 14:52:45
 Re: Ford 800, PTO engaging problem in reply to old, 04-02-2013 08:26:56
in this case.. specific model won't matter.. 8X0 will have same shifter setup..
old
04-02-2013 14:56:13
 Re: Ford 800, PTO engaging problem in reply to soundguy, 04-02-2013 14:52:45
Yes but if it was the 860 that could cause a different type of problem like a stuck clutch disk
philcoinms
04-09-2013 13:06:26
 Re: Ford 800, PTO engaging problem in reply to old, 04-02-2013 14:56:13
ok three questions
Can I repair the PTO shifter without removing it?
If I remove it do I have to break the tractor in half
and Is the Shifter the same for the N series and 800
Sean in PA
04-09-2013 13:29:26
 Re: Ford 800, PTO engaging problem in reply to philcoinms, 04-09-2013 13:06:26
As old already said, you should pull the round plate off the left side where the PTO shift lever is to see what you've got first. You may be able to fix it without splitting the tractor, but we can't tell you for sure until we know the exact nature of the problem.
And no, the shifter on the 800 series is not the same as on an N series. They function in a similar fashion, but the exact parts and layout are different.
soundguy
04-02-2013 15:03:47
his pto was jumping out of gear, not staying engaged.. and now not engaging.
if it was a simple stuck pto section.. he could shift it into engaged position with machine off, and then run it.
don't sound like that's the case though.
old
04-02-2013 16:05:03
 Re: Ford 800, PTO engaging problem in reply to soundguy, 04-02-2013 15:03:47
It is still a good thing to know what model one has so if there are thing that could come into play it makes it easier for us to help them
philcoinms
04-07-2013 09:11:42
 Re: Ford 800, PTO engaging problem in reply to old, 04-02-2013 16:05:03
YES MINE IS A 860
soundguy
04-02-2013 16:15:01
yes, he SHOULD know what tractor he owns.
old
04-02-2013 16:39:21
 Re: Ford 800, PTO engaging problem in reply to soundguy, 04-02-2013 16:15:01
I have seen some very odd problems over the years and a simple bad bearing or snap ring can and will cause some very odd problems from time to time. Like on my 1980 Chev lock out hubs having the snap ring in the wrong place it has two place makes it so the lock out will not lock in
