Back in the late 50s and early 60s Ford had three remote valves to fit 100'a series tractors. I know I am old and senile but I sure I am correct since I worked at a dealer from 1957 - 1964. And to further solidafy my beleif, I started farming in 1964 with a 960 and a 860 and have had all three of them. A non detended single spool, a non detented double spool valve ,and the one in most parts book which is a dented single valve. There was also a lever operated valve that could be put on the single spool detented valve to make it function like a double dented valve. Had it also. .Now my questions. Where in any Ford book do you find any thing but the single spool detented valves or the selector? Also I would like to get some banjo type fittings that would except a 3/8s hyd hose along with the hollow bolt that fit the banjo fitting. These fittings were used on all of the above valves. Sorry for the long post, just hope some one understns this!
