Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Order Ford 3400 Parts Online
Re: 3400 6 speed fill and check plugs
Sean in PA
04-01-2013 14:51:09
This information should be in your owner's manual. If you don't have one you should get one. Better yet, buy an I&T manual, they're only about $30.00, and your new mechanic will thank you for it, plus he'll have no excuse for doing something wrong.
Transmission fill hole is large hex head on the top plate of the transmission, just forward of where the the hi/low shifter goes into the top plate. The level check hole for the transmission is a small square headed pipe plug on the right side of the transmission just forward of the brake pedals.
Rear axle/hydraulics fill hole is large hex head on top of the differential housing, directly under your right butt cheek when you're sitting on the tractor. Level check hole for rear axle/hydraulics is a small square headed pipe plug on the right side, near where your right heel is when you're sitting on the tractor.
This post was edited by Sean in PA at 14:53:19 04/01/13 2 times.
Copyright © 1997-2015 Yesterday's Tractor Co.
