960- Sherman
Anonymous-0
Does anyone know if a Sherman transmission can be installed in a 1955 960? I was just given a Sherman and my son has a 960 that he uses on a back-up style snow blower. The reverse travel speed is to fast and requires one to ride the clutch... When I install the new clutch it will be the right time to install the Sherman if possible or trade the 960 for something that travels slower.
Change the transmission to a 4 speed, related stuff and install the Sherman and you are good to go.
Vito
The 960 has a double clutch, giving you "live" PTO.
Just something to consider if you modify it.
Sherman is not an option. Even if it would work with a five speed, which it will not, it would slow down the snowblower as well as the ground speed.
a clutch is not meant to be a speed control device. riding it to constantly reduce speed will eat it.
sherman pre trannies work with no 5spd trans..
