TractorLinks.com
Order Ford 640 Parts Online
Re: Ford 640 - How should the coil be wired
old
03-28-2013 09:20:35
Sounds like you not good with basic wiring in general. Saying left and right means little or nothing to us since we can not see the tractor. That said it should be a + ground tractor meaning the + battery cable should be bolted to the frame some place and the - to the solenoid. The coil should have the + side of it going to the distributor since the points are what ground the coil and the - to the ignition switch. Next pull the distributor cap and rotor and dust cover. Get the points closed and carefully open and close the points by hand. You should with the ignition on both see and hear spark and if you do not then clean the points or replace them good chance the points are dirty or corroded. By the way if you not careful you may find the spark the hard way by ground the point by way of your body
tgemignani
03-28-2013 10:01:09
 Re: Ford 640 - How should the coil be wired in reply to old, 03-28-2013 09:20:35
Should the coil still be okay if it started with the negative connected to the distributor?
old
03-28-2013 13:06:56
 Re: Ford 640 - How should the coil be wired in reply to tgemignani, 03-28-2013 10:01:09
Yes coils are pretty much bullet proof and the only reason it should be hooked up the right way is so the spark jumps the correct way
soundguy
03-28-2013 11:37:02
ditto what jmor said.
the coil backwards thing is something you could see on an oscope or other specialized equipment.. etc..
tgemignani
03-28-2013 12:21:49
 Re: Ford 640 - How should the coil be wired in reply to soundguy, 03-28-2013 11:37:02
Thanks guys I appreciate all the good info. I'm going to check the points this weekend.
It's running like garbage currently but I attribute that to it being a south Texas tractor that was transplanted to northern Kansas in sub zero temps.
old
03-28-2013 19:01:33
 Re: Ford 640 - How should the coil be wired in reply to tgemignani, 03-28-2013 12:21:49
Also check the air cleaner. Those are one thing few people service and can cause many problems if filled with water which if cold will freeze and then you get a non-running engine
tgemignani
03-28-2013 19:16:13
 Re: Ford 640 - How should the coil be wired in reply to old, 03-28-2013 19:01:33
Once again I appreciate the info.
I have the tractor running at idle but it seems to be missing. When I advance the throttle to high RPM it runs decent for a bit but when warm I can't bring the throttle back down or it will rev from high to low and eventually die.
On a possibly related note, quite a bit of fuel (a puddle) is leaking from the carb when the tractor is off from what appears to be the throttle linkage. I'm assuming it needs a carb rebuild but I didn't know if the missing and inability to go to low rpm is mostly spark related.
Thanks
old
03-28-2013 19:34:56
 Re: Ford 640 - How should the coil be wired in reply to tgemignani, 03-28-2013 19:16:13
As Royce said good to shut the gas off when not running or you can get gas in the oil and that can mean an engine rebuild. If in fact the leak is at the throttle shaft that is a vacuum leak and that will cause odd problems and needs fixed
Royse
03-28-2013 19:24:11
Its always a good idea to shut the fuel off when the tractor is off.
The fact that its leaking is, as you said, is an indication of it needing carb work.
At the least the needle valve is not seating correctly.
That's a pretty common thing on tractors that have set for a while though.
A decent carb rebuild may solve the majority of the problems.
Still a good idea to service the air filter and any other items that have been neglected.
soundguy
03-28-2013 17:29:42
some tractors need a lil more main needle in the cold. you can test this with a tug of choke...
JMOR
03-28-2013 10:13:08
Sure should, as a matter of fact it works just fine either way!
36 coupe
03-31-2013 04:44:37
 Re: Ford 640 - How should the coil be wired in reply to JMOR, 03-28-2013 10:13:08
When the points open we have an alternating voltage so polarity doesnt matter.
