Block heater?
Jim.UT
Pulled this photo off a CL ad for a Jubilee in Wyoming. I assume that tube running from just below the alternator to the side of the oil filter is some sort of coolant heater. Does it plug into the block drain? It looks like it would make removing the oil filter a real chore.
Commonly called a tank heater around here. Yes , they do use the block drain hole. I prefer a regular block heater that replaces a 'frost' plug in the block. (like David said)
