Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Order Ford 800 Parts Online
Re: 800 won't stay running
old
03-26-2013 18:40:10
Yes and it needs to be a blue/white in color and jump a 1/4 inch gap or more NO MATTER what. Sounds like you have poor spark and could be as simple as point gap wrong Needs to be 0.025 or a weak ignition switch
Finneas
03-27-2013 11:03:43
 Re: 800 won't stay running in reply to old, 03-26-2013 18:40:10
I set the gap at .025. The poor ignition switch is a possible. It's the original and does feel a little loose. When I get back to it i think that's the first thing I will check. I have one in the garage from my riding mower, I think I'll just change it and see what happens.
old
03-27-2013 12:01:15
 Re: 800 won't stay running in reply to Finneas, 03-27-2013 11:03:43
Shoot to check for a bad switch just do a simple hot wire. Just run a wire from the ignition side of the battery to the ignition side of the coil and try to make it run. If it runs fine then you have a bad switch or bad wires from the coil back. Also check the spark with it hot wired
