Yesterday's Tractor Co.
Shop Now View Cart
Order Ford 800 Parts Online
Re: 800 won't stay running
03-26-2013 16:48:14
First check and make sure you have a good blue/white spark that jumps a 1/4 inch gap or more.
Next pull the carb drain plug and make sure you have a good steady flow of gas from it for say 3 minutes. Catch that liquid gold so you can use it and also look for water etc in it. Next screw the main jet the one close to the bottom of the carb out say 3 turns. See if it will run then. Post back if any of this helps or not so we can help you more
03-26-2013 17:37:47
 Re: 800 won't stay running in reply to old, 03-26-2013 16:48:14
I can't get back to it for a few days, but I do know I have a yellowish spark from the center coil wire to a ground. Is that the spark you referred to?
03-26-2013 18:40:10
 Re: 800 won't stay running in reply to Finneas, 03-26-2013 17:37:47
Yes and it needs to be a blue/white in color and jump a 1/4 inch gap or more NO MATTER what. Sounds like you have poor spark and could be as simple as point gap wrong Needs to be 0.025 or a weak ignition switch
03-27-2013 11:03:43
 Re: 800 won't stay running in reply to old, 03-26-2013 18:40:10
I set the gap at .025. The poor ignition switch is a possible. It's the original and does feel a little loose. When I get back to it i think that's the first thing I will check. I have one in the garage from my riding mower, I think I'll just change it and see what happens.
03-27-2013 12:01:15
 Re: 800 won't stay running in reply to Finneas, 03-27-2013 11:03:43
Shoot to check for a bad switch just do a simple hot wire. Just run a wire from the ignition side of the battery to the ignition side of the coil and try to make it run. If it runs fine then you have a bad switch or bad wires from the coil back. Also check the spark with it hot wired
