Yesterday's Tractor Co.
Shop Now View Cart
Order Ford 800 Parts Online
Re: 800 won't stay running
03-26-2013 16:18:31
I don't recall the other post, but do you have good gas flow to and through the carb?
Should be able to take the drain plug out of the bottom and catch it in a can.
Let it run a couple minutes and make sure it remains a steady flow.
If not you could have a plugged line, screen or a non-venting gas cap.
There could also be gunk still stuck in the carb. Sometimes blowing the passages
out with air isn't enough and you need to run a wire through them.
All assuming it has plenty of gas in it of course. Don't over-look the obvious! :)
03-28-2013 06:01:28
 Re: 800 won't stay running in reply to Royse, 03-26-2013 16:18:31
No fuel pump, It"s gravity feed, So make sure your cap is vented, there are no "sags" in your fuel line and as long as you have the proper screen leaving fuel tank and entering carb. plus proper sediment bowl you don"t need an inline fuel filter! Good Luck GT65
