Anonymous-0
Hi
i just replaced the fuel pump, the old one was leaking, it was running before, but now it will not crank (i did make sure that the fule pump is set to the same holes, and it is at the o degree mark). I am thinking that i did not get the correct timing mark. Actually really cannot find one, on the crankshaft gear. so which piston is # one? from the front of the engine/tractor? thinking if i know this i can look at the valves at the top to know when/where it is, and should be able to get timing of the fuel pump set that way.
