TractorLinks.com
Order Ford 600 Parts Online
Re: Ford 4600 timing
Ultradog mn
03-24-2013 06:32:57
Micky, #1 piston is the one closest to the radiator.
But the truth is I don't know where #1 is in relation to the photo I posted. I think at this point I would recheck the front gears to match the photo. The pump gear is indexed to the shaft so it can't get out of time there.
BTW, most of these tractors I have seen the pump was not set to the zero line but 1 to 1 1/2 lines below zero.
Micky Kilpatrick
03-24-2013 13:04:35
 Re: Ford 4600 timing in reply to Ultradog mn, 03-24-2013 06:32:57
thanks on that, is it possible (i got it as a used tractor), that someone has done some engine work, and did not put the camshaft drive gear back in the correct oreintation? The reason why i ask, i can not get any of the three timing dots on the camshaft drive gear to line up with the either the Camshaft gear's one dot, or the crankshaft gears one dot. But there is a tool mark, like a punch was used, on the camshaft drive gear, and if i use that to align to the crankshaft, i also get the camshaft gear's dot at the 9'oclock posistion as shown in your picture.
Right now i think i will pull the valve cover off the top and see if i can make that #1 is at top.
