TractorLinks.com
Order Ford 600 Parts Online
Re: Ford 4600 timing
Kirk Grau
03-23-2013 17:23:09
I am going to ask for clarification of "will not crank". If you are saying it does not even turn over/spin (which is how I would interpret "will not crank") I would be looking at starter/battery cables/switch/generally following voltage around to see where the circuit might be broken. If it is spinning, but not fireing, might want to make sure you have the system bled since you removed the pump. Unless you rolled the engine while the pump was off it should not have gotten out of time enough to not be able to start. If you did spin the engine then you need to ask UD to scan the pages from his manual and forward them to you. I have them as well.
Good Luck,
Kirk
