TractorLinks.com
Show Parts for Model:
Re: 12 v positive or negative ground
equeen
03-23-2013 15:21:26
Royce,
Objective was not to just go willy-nilly and change out VRs, gens, etc; but rather to test to see what works and what doesn't.
1 & 2 were results of questions relating to a 650 Ford. My understanding was that there is a measurable reading from ARM to BAT IF the VR is good - if not, then replace. Further, there should not be a measurable reading between ARM and FLD is VR is good - thus replace if get a reading.
In fact, those instructions seemed to have been reliable regarding an 8N and a 650. But, will verify or correct notes at the proper time.
But, no one should take my word for anything. I'm the trainee/learner, not the wizard. Pleased that lots of experts respond to posts such as mine - and try to get me on the "straight and narrow".
JMOR
03-23-2013 15:48:25
 Re: 12 v positive or negative ground in reply to equeen, 03-23-2013 15:21:26
Been watching from sidelines, but have a question for you, equeen, when you say, "jump from ARM to BATT", what does that mean? And when you speak of "see a reading" or "see no reading", are you referring to voltage, amperes, or Ohms?
equeen
03-23-2013 16:43:23
 Re: 12 v positive or negative ground in reply to JMOR, 03-23-2013 15:48:25
Apologize for my wording/terminology.
I'm actually checking for voltage reading with one probe on the ARM terminal of the VR, the other on the BAT terminal of the VR, etc. Thus, I either see a reading or else see no reading. This is done with the engine running, all wires connected, etc.
JMOR
03-23-2013 16:50:24
 Re: 12 v positive or negative ground in reply to equeen, 03-23-2013 16:43:23
equeen said: (quoted from post at 19:43:23 03/23/13) Apologize for my wording/terminology.
I was beginning to suspect that. You see, about most of the population will take "jump from A to B", to mean that you shorted A to B with a jumper wire or a screwdriver or pliers or some other conductive object, rather than that you connected a voltmeter between the terminals, A and B. Clear communications is difficult! Sender & receiver may end up in two different worlds. This I'm afraid makes much of what has been said, null & void.
This post was edited by JMOR at 16:51:44 03/23/13.
equeen
03-23-2013 16:59:20
 Re: 12 v positive or negative ground in reply to JMOR, 03-23-2013 16:50:24
Thanks for getting me on the right track with my terminology. Yes, I can see that words do make a difference - and my words can get wacky.
