Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: 12 v positive or negative ground
Royse
03-23-2013 14:05:33
equeen, might I suggest you at least do a thorough review of your notes?
The one you posted here says to jumper with a voltmeter.
I can't see what that would get you except a voltage reading.
It also has the same result for both scenarios. Replace the regulator.
If you're just going to replace it either way, why do the tests?
"1. Using volt meter momentarily jump the ARM and BAT terminals. Charge should be about 7.8. If not, then replace the regulator.
2. Jump the ARM and FLD terminals. If there is a charge, then replace the regulator. "
equeen
03-23-2013 15:21:26
 Re: 12 v positive or negative ground in reply to Royse, 03-23-2013 14:05:33
Royce,
Objective was not to just go willy-nilly and change out VRs, gens, etc; but rather to test to see what works and what doesn't.
1 & 2 were results of questions relating to a 650 Ford. My understanding was that there is a measurable reading from ARM to BAT IF the VR is good - if not, then replace. Further, there should not be a measurable reading between ARM and FLD is VR is good - thus replace if get a reading.
In fact, those instructions seemed to have been reliable regarding an 8N and a 650. But, will verify or correct notes at the proper time.
But, no one should take my word for anything. I'm the trainee/learner, not the wizard. Pleased that lots of experts respond to posts such as mine - and try to get me on the "straight and narrow".
JMOR
03-23-2013 15:48:25
 Re: 12 v positive or negative ground in reply to equeen, 03-23-2013 15:21:26
Been watching from sidelines, but have a question for you, equeen, when you say, "jump from ARM to BATT", what does that mean? And when you speak of "see a reading" or "see no reading", are you referring to voltage, amperes, or Ohms?
equeen
03-23-2013 16:43:23
 Re: 12 v positive or negative ground in reply to JMOR, 03-23-2013 15:48:25
Apologize for my wording/terminology.
I'm actually checking for voltage reading with one probe on the ARM terminal of the VR, the other on the BAT terminal of the VR, etc. Thus, I either see a reading or else see no reading. This is done with the engine running, all wires connected, etc.
JMOR
03-23-2013 16:50:24
 Re: 12 v positive or negative ground in reply to equeen, 03-23-2013 16:43:23
equeen said: (quoted from post at 19:43:23 03/23/13) Apologize for my wording/terminology.
I was beginning to suspect that. You see, about most of the population will take "jump from A to B", to mean that you shorted A to B with a jumper wire or a screwdriver or pliers or some other conductive object, rather than that you connected a voltmeter between the terminals, A and B. Clear communications is difficult! Sender & receiver may end up in two different worlds. This I'm afraid makes much of what has been said, null & void.
This post was edited by JMOR at 16:51:44 03/23/13.
equeen
03-23-2013 16:59:20
 Re: 12 v positive or negative ground in reply to JMOR, 03-23-2013 16:50:24
Thanks for getting me on the right track with my terminology. Yes, I can see that words do make a difference - and my words can get wacky.
Copyright © 1997-2015 Yesterday's Tractor Co.
