Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Order Ford 600 Parts Online
Re: acceptable compression range for a 600
craigss
03-20-2013 16:35:10
actual compression should be from 120-130 . I would first check all valve rocker arm adjustments and timing. but is possible that all rings are that worn. do a dry comp test then perform a wet test, if wet test improves the comp then you have bad rings or sleeves, if no improvements on any of the four then i would check timing and valve rack
