861 with fresh rebuild brush hog mower size
ShowMEguy
I am looking for a bigger brush hog or even a flail mower for my newly rebuilt 1960 Ford 861. How big can I go to mow around this pond and say the waterways in your guys opinion? I plan on mowing it 2-4 times a year... Here is a pic of what I'm mowing nwo with my 2n and 5 footer.
Would a 8foot dual spindle brush hog be to much? How large of a flail? or rotary would you all recommend for that I'm mowing? I wanna go a big as possible to cut more of it....
an 800 will tote a 6' hog easilly. not sure on flail mower sizes.
7' will be tooo heavy.. and 8' is just getting too big IMHO..
I never had a flail mover but my understanding is that they take less
power per foot of cutting width than a rotary mower. Your 2N or
your 861 could easily power a 9' sickle bar mower, but it would just
lay the grass down rather than chopping it.
Zach
I use a 6 foot bush-hog style on my 861,I wouldn't go any bigger as in my opinion it would be hard on the pto driveline.
Six foot is as much rotary cutter as I would use. But, assuming that trees and reeds like to grow right down to the water's edge in Mo. as well as they do in Pa., I think you'll want the sickle bar for one pass around the shore, and maybe for passing across nearby soft spots that you'd rather not risk getting stuck in.
Good luck.
Ray
I agree that a 7' is too much for that 134 cu. to be powering.
We use our 660 with a 7' 501 sickle bar mower to cut hay in
the summer. We travel across the field is 3rd gear about
1300rpm. I'm afraid that a 6' might be too heavy for the cat 1
lift, not that I don't doubt it won't pick it up, but the front end
might be light.
Sounds like I'm gonna need to try to find a 6 footer and find a used sickle mower... I hadn't thougth of a sickle for the pond bank.. been using the stihl on the parts I wanna clean up..
