TractorLinks.com
Show Parts for Model:
Re: Steering shaft end play
Brian Allen
03-19-2013 14:36:48
Quietwater
You are also about to learn that the two sector shafts only go in one way!
Also, center your steering by counting the turns, if you have everything correct, it will turn the same amount of turns in each direction.
If it is not right, do it again until it is!
"And", if you set the adjustment too tight you will have very hard to turn steering. Note, some play in the straight ahead position is normal in worn parts.
To get rid of that, the sector shafts and steering shaft assembly, have to be replaced.
Brian
