axel trumpet
Larharm
Need some advice on removing the axle trumpet from 631. Take the wheel off and drain oil from dif and remove the nuts from dif. From there on I don't know if the axle will just slide out
From what I can see in the I-T manual yes the axle should just slide right out as a whole assembly with the trumpet
have a cherry picker and load levler handy and be carefull... that trumpet, axle nad brake assy w/hub is quite a chunk of metal.
