ford 4500 tractor
Nelson1
New User
I have a ford 4500 tractor with backhoe if I take off the backhoe what do I do with the three lines on the tractor can I just plug them.
Two of the hoses should connect back together to allow the oil to continue to flow to the front loader. One should have a male fitting, and the other female. The third return line to the loader frame needs to be capped. There is a threaded boss under the backhoe floorboard where the cap can be stored - if you are lucky the cap is there!
