TractorLinks.com
Order Ford 800 Parts Online
Re: Ford 800 ignition problem
Ed Hotaling
03-17-2013 12:13:48
First, make a visual check. I have been known to leave something disconnected and not realize it. Do you have power to the coil? To the points? Do the points spark when you open them by hand? That's the easy stuff. Also check the insulator where the low voltage wire enters the distributer. I don't know if it would happen with a battery ignition, but I have timed a magneto 180 degrees out. It would fire on the top of the exhaust stroke instead of compression. The easy way to check that one is to switch the plug wires across the distributer cap. I have had an engine run for many years like that.
