Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Order Ford 801 Parts Online
Re: 801 Powermaster Timing of Injection pump after rebuild
Dieseltech
03-15-2013 09:48:05
When # 1 is at TDC compression #4 valves will be rocking, exhaust closing and intake opening. Then back up to about 30 degrees, then turn forward to 23 degrees to remove gear backlash. This is where pump needs to be, and will be correct IF retainer is assembled and marked correctly.
10 Bluebird
03-15-2013 11:14:01
 Re: 801 Powermaster Timing of Injection pump after rebuild in reply to Dieseltech, 03-15-2013 09:48:05
Thank you very much. What is the retainer?
Dieseltech
03-15-2013 11:53:36
 Re: 801 Powermaster Timing of Injection pump after rebuild in reply to 10 Bluebird, 03-15-2013 11:14:01
Pump timing mark is stamped on governor weight retainer inside of the pump.
