I just bought a 65 ford 5000. After reading on here I learned that it had a button on the side of the Simms injector pump for staring it cold. After pulling the throttle half way back I tryed to push it in but it wouldn't budge. I took the handle of a screwdriver and finally got it pushed in but when I started it, it didn't pop back out. It seems to be running fine what little I've run it. I thought that it was supposed to throttle wide open until you push the throttle back to idle. I tryed to pull it back out but again it wouldn't budge. Has anybody ran into this problem, if so how do you fix it and will it hurt to just run it that way.
Thanks in advance for any help.
