TractorLinks.com
Order Ford 971 Parts Online
Re: Ford 971 Select-O-Speed -- What's It Worth?
Larry NCKS
03-14-2013 18:50:12
It actually will freewheel in 5 forward speeds. It's just that 1&2 are so slow they didn't think it would be a problem and didn't mark the shifter in those positions.
An easier way to tell is to look at the casting # on the left side of the transmission. A 312259 above and behind the inching pedal is the original less desirable transmission. Anything else there is better.
Ronald Wilcox
04-16-2013 17:39:23
 Re: Ford 971 Select-O-Speed -- What's It Worth? in reply to Larry NCKS, 03-14-2013 18:50:12
I am considering buying a 871 - year unknown as I couldn't find the serial number over the starter housing. I did see a number on the side of the SOS, but didn't write it down. Have reviewed some of the threads and am concerned (to some degree) about the SOS as I have a Ford Industrial 4400/loader that REALLY sluggish shifting into reverse.
I have a 1958 851 with a 5 speed (an bad engine). I am considering the option of replacing the SOS with the 5 speed if needed. I see someone did this to a 801 in another post - but current owner didn't do.
Can anyone tell me if is possible, and if it is, how difficult (and costly???).
New to forum, so open to critique .
Larry NCKS
04-16-2013 18:28:13
 Re: Ford 971 Select-O-Speed -- What's It Worth? in reply to Ronald Wilcox, 04-16-2013 17:39:23
It would be better to start this in a new post (that's my critique :wink: )
It is very possible to convert from one trans to another and many would advise installing the 5 speed in place of the SOS. I'm not one of them! I'd sell the blamed 5 speed to one of its advocates and fix the SOS - if indeed there is something wrong with it.
Mrs. Diamond
03-15-2013 06:32:59
Thank you "Showcrop" and "Larry". I will check that number and get back to you (because I don't know what it means to "freewheel" :-)
