Hello All,
I have a fuel line that is about 4 inches to short. This is because a fuel shut off valve was put in at the fuel bowl. So they cut the fuel line attached a short fuel hose then the shut off valve.
I want to get rid of the shut off because it leaks. Can I use a small piece of NAPA brake line and attach that to the fuel hose/line..... the brake line would then screw into the gas bowl assembly.
I think the inside diameter of the fuel line is 1/4 inches (ID) on a 641.
I will be replacing the fuel line in the future so this is just a temp job.
Thanks Ralph
Thanks Ralph
