TractorLinks.com
Show Parts for Model:
Re: 6700 256 engine
james r
03-14-2013 07:33:58
thanks for all the help.I'm will get pistons for a 268 and try them if that works I will let you know . again thanks to all of you.
RodInNS
03-14-2013 16:19:00
 Re: 6700 256 engine in reply to james r, 03-14-2013 07:33:58
Take those numbers to the dealer and have him double check them and make sure it's a 268. There's a lot of different pistons avaliable even for a 268...
Rod
Bern
03-15-2013 06:03:31
 Re: 6700 256 engine in reply to RodInNS, 03-14-2013 16:19:00
Rod,
What else could it be if the crank has 4.4 cast right on it?
RodInNS
03-15-2013 07:41:02
 Re: 6700 256 engine in reply to Bern, 03-15-2013 06:03:31
If it's got 4.4 cast on the crank... I guess it's a 268. To be honest, I forgot that he posted that in an earlier post.
It's still nice to know with certainty what the engine is exactly. You know as well as me that there's some very tight unit code breaks on specific parts on those engines, particularly around the water pump... that he ought to know even if it's not overly relevant to ordering pistons.
Rod
james r
03-15-2013 14:45:55
 Re: 6700 256 engine in reply to RodInNS, 03-15-2013 07:41:02
I took the numbers to a dealer and call 3 outher dealers with them . I guess they are still scrathing their head over them.They could not tell me anything.Y'all have told me more than anybody.
Bern
03-15-2013 15:18:07
 Re: 6700 256 engine in reply to james r, 03-15-2013 14:45:55
If the bore is 4.4", and the stroke is 4.4", then it's a 268. Period. End of story.
About the only other thing you need to be aware of is the difference between turbo and non-turbo pistons. Non-turbo pistons will stick up about .010" taller than non-turbo pistons. You want a non-turbo engine's piston protrusion to be about .011-.023" above the top of the block at TDC.
RodInNS
03-15-2013 18:11:07
 Re: 6700 256 engine in reply to Bern, 03-15-2013 15:18:07
Yeah... if it's got a 4.4" bore and 4.4" stroke it's a 268 but that doesn't mean every part is the same in all N/A 268 engines. Most things are exchangeable as sets but you would not want to mix and match pistons from different generation engines....
Rod
Bern
03-15-2013 16:08:07
Oops, I meant to say non-turbo pistons stick up taller than turbo pistons. Turbo engines have a lower static compression ratio.
james r
03-22-2013 13:25:55
 Re: 6700 256 engine in reply to Bern, 03-15-2013 16:08:07
i would like to thank the ones that help me. I got the new pistons in today for 268 and they fit.
