Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: 6700 256 engine
welding man
03-13-2013 09:33:06
Is that the part # on the old or new Piston? Are you sure you don't have a 6710 or a BSD replacement engine? Piston heights are different by about 100 thousands.
james r
03-13-2013 14:01:15
 Re: 6700 256 engine in reply to welding man, 03-13-2013 09:33:06
that is the # on the new piston. looking a the crank it has 4.4 on it. someone could have change engines. what is a bsd engine .if a 256 has 4.2 and 268 has 4.4 would that make the 2mm diffrent in height in the piston.
RodInNS
03-13-2013 14:38:16
 Re: 6700 256 engine in reply to james r, 03-13-2013 14:01:15
IIRC, there's different pin heights on a 4.2 vs 4.4 stroke piston.
BSD engine = Basildon Service Diesel. They're basically a Ford tractor engine of whatever vintage the given engine was produced... just that it was sold as an industrial engine or as a replacement engine for Ford tractors.
You need to get the engine numbers off the pan rail and also see if it's got an engine date code stamped on the right front upper mounting ear. BSD engines also generally have a DPS rotary injection pump (lines come out the end of the pump head) and will also have a cross hatched block design. The original engine in your tractor will have a Simms/Minimec pump and the block will NOT be crosshatched.
So... figure out what you have first and foremost.
Rod
james r
03-13-2013 15:51:23
 Re: 6700 256 engine in reply to RodInNS, 03-13-2013 14:38:16
#'s offpan rail *891501*. #'s off mounting ear ECE 60A11 6A20A . My tractor was made in england I found that out when I bought a starter for it.I hope this helps find what I need to know.I am sure it has Simm/Minmec pump.The fuel lines come out the top. And thanks I am finding out A lot more about this tractor.
RodInNS
03-13-2013 20:45:07
 Re: 6700 256 engine in reply to james r, 03-13-2013 15:51:23
Are there any numbers on the other pan rail?
E1NN and the date code of 6A20A suggest to me that the engine was built up on Jan 20 1986. If you're sure it's a 4.4" stroke crank then you're definitely ordering parts for the wrong engine. Given the other numbers I'm kinda of the mind to say it's a 268 or a BSD 444.
Rod
Bern
03-13-2013 19:14:08
If you have a 268 engine (4.4 stroke), and you are ordering parts for a 256 (4.2 stroke), then yes, you indeed have the wrong pistons.
james r
03-14-2013 07:33:58
 Re: 6700 256 engine in reply to Bern, 03-13-2013 19:14:08
thanks for all the help.I'm will get pistons for a 268 and try them if that works I will let you know . again thanks to all of you.
RodInNS
03-14-2013 16:19:00
 Re: 6700 256 engine in reply to james r, 03-14-2013 07:33:58
Take those numbers to the dealer and have him double check them and make sure it's a 268. There's a lot of different pistons avaliable even for a 268...
Rod
Bern
03-15-2013 06:03:31
 Re: 6700 256 engine in reply to RodInNS, 03-14-2013 16:19:00
Rod,
What else could it be if the crank has 4.4 cast right on it?
RodInNS
03-15-2013 07:41:02
 Re: 6700 256 engine in reply to Bern, 03-15-2013 06:03:31
If it's got 4.4 cast on the crank... I guess it's a 268. To be honest, I forgot that he posted that in an earlier post.
It's still nice to know with certainty what the engine is exactly. You know as well as me that there's some very tight unit code breaks on specific parts on those engines, particularly around the water pump... that he ought to know even if it's not overly relevant to ordering pistons.
Rod
james r
03-15-2013 14:45:55
 Re: 6700 256 engine in reply to RodInNS, 03-15-2013 07:41:02
I took the numbers to a dealer and call 3 outher dealers with them . I guess they are still scrathing their head over them.They could not tell me anything.Y'all have told me more than anybody.
Bern
03-15-2013 15:18:07
 Re: 6700 256 engine in reply to james r, 03-15-2013 14:45:55
If the bore is 4.4", and the stroke is 4.4", then it's a 268. Period. End of story.
About the only other thing you need to be aware of is the difference between turbo and non-turbo pistons. Non-turbo pistons will stick up about .010" taller than non-turbo pistons. You want a non-turbo engine's piston protrusion to be about .011-.023" above the top of the block at TDC.
RodInNS
03-15-2013 18:11:07
 Re: 6700 256 engine in reply to Bern, 03-15-2013 15:18:07
Yeah... if it's got a 4.4" bore and 4.4" stroke it's a 268 but that doesn't mean every part is the same in all N/A 268 engines. Most things are exchangeable as sets but you would not want to mix and match pistons from different generation engines....
Rod
Bern
03-15-2013 16:08:07
Oops, I meant to say non-turbo pistons stick up taller than turbo pistons. Turbo engines have a lower static compression ratio.
james r
03-22-2013 13:25:55
 Re: 6700 256 engine in reply to Bern, 03-15-2013 16:08:07
i would like to thank the ones that help me. I got the new pistons in today for 268 and they fit.
Copyright © 1997-2015 Yesterday's Tractor Co.
